MW Folding Side Adjust Lever Set: 999/1098/S4RS/HM/SF-Black
Was: $260.00
Sale: $199.00
A multi-adjustable lever with a unique aerodynamic shape, and the folding lever gives extra function to the brake and clutch lever.
Extensive wind tunnel studies have shown that at speeds above 180 km per hour, the force of the air causes movement of the lever, which puts the hydraulic circuit under pressure, limiting the bike’s performance. These levers reduce this detrimental effect to the minimum.
Aesthetics and practicality are naturally of the highest order the lever is shaped from a solid piece of aluminum.An articulated joint is added to avoid breakage in the event of a slide.
The technology used in the construction is of the highest order; the lever offers a wide range of adjustment and moves on bearings with return springs specifically for operational precision, reliability and durability.
FITS: All OEM Brembo radial master cylinders featured on Ducati 749-999 / 848-1098 / 07+S4R -S4RS / M1100 / Hypermotard / Streetfighter...
http://motowheels.com/images/F29133361.jpg
http://motowheels.com/images/F29133364.jpg
