Lets pick up this old thread and run with it....
I have the opposite, i have a 999 that i want to fit a multistrada triple onto. All the guys on eBay are affraid of tape measures for some reason. Was wondering if some of you guys could help me
Just looking for dimensions for the upper triple on the 1000, 1100 and 1200 models
To make it easier, i want to know about any triples that have the steering damper mount on the back edge of it. Possibly S models ? fork diameter is irellevant, as i can get them machined out to 53mm if needed...
Ok, measurements i need are...
Measurement A: Fork holes from center to center.
Measurement B: Offset measurement. from centerline between fork mounts to center of steering shaft mount and the diameter of the steering shaft mount hole.
Measurement C: From center of steering shaft hole to center of steering damper mounting hole...
I know the photo i have is of a 999 top clamp, sorry i cant find a multistrada photo.
Many thanks in advance
Jason
