Can you fit it?
I heard somwhere that the cases where narrower were the swing arm meets the engine?
Can it be fixed with spacers etc?
why would you do that in the 1st place?
Donor engine.
Im gonna get an 1000ds spare engine and give it to my engine guy and keep the original engine so when i sell it i can put it back in.
Basically gonne build a race engine.
By my guru mechanic you can do that, also with Hyper engine.
BTW, i have a sport 1000 and a multi 1100s..believe me people...the engine is way difference: aggressive and faster respond.
If i can find one myself i will do it, but i am looking for a hyper one with dry clutch.
the multi has a different setup for the swingarm attachment due to the single-sided design. the swingarm bearings are mounted differently in the cases. i'm not sure if this is a deal-breaker, but it may require some fiddling in that area...
