1 - 2 of 2 Posts
I have a 13 GT and now my heated grips quit working. I looked in the manual to see if there was a fuse for them but nothing was mentioned. Everything electrical seems to be working. Unfortunately the dealer is 100 miles away. Thoughts please?
The first action should be to locate the connectors for each grip and check for voltage when the switch is active. If you measure voltage at the connectors and the grips aren't heating, then its likely that the grips have failed. They are a resistive element and they can wear out or fail.
1 - 2 of 2 Posts
