1 - 9 of 9 Posts
Sounds great! pretty wicked note actually....only thing is it does not come with the Mid Pipe (between the headers & the end can), as Zard decided the existing one did the job sufficiently.....otherwise, fit and finish great, and has the CO sensor port for the 1100 motor...
Thats a pretty wicked looking system. The 999 rear looks great.
Discussion Starter #6 (Edited)
Thanks Guys, took the Multi out for a couple of hours today, down through the National Park just south of Sydney here, sounds really wicked through the forests and twisties....is seems pretty quiet above about 6500/7000rpm, but has a really nice note on the deceleration...pops and cackles a bit....really happy with the system, and thoroughly recommend it...next up is a K & N air filter and open up the airbox, then add a Power Commander or Rapid Module....
Like to see dyno numbers after you complete the performance upgrades.
Well that pipe looks great and the sound bites i heard sounded good too.
Sofar that muffler and the Famsa bags are going to be my first mods. :D
Do they offer just a slipon till i can change the header pipes?
Discussion Starter #9
YEP, you can get just a slip on can, then get the headers later...the system uses the existing mid pipe anyway so will fit easy..
1 - 9 of 9 Posts
