1 - 20 of 20 Posts
Hello,
So, I've had a setback while mounting my Givi TN7413 crash bars on my MTS V4.
I had the bike on the center stand and when I unplug the 2 screws near the right footpeg (red), all that part went upwards (blue) and now I can't screw the bolts to lock that position.
The first impulse was to change the bike from the center stand to the lateral one.
Can anyone help me with this issue? Is there a way to unmount all that set piece and lower it?
I'm a little worry about taking it to the dealer because of the warranty.
Thank you.
Organism Font Motor vehicle Automotive design Auto part
Tire Crankset Bicycle tire Automotive tire Wheel
Hello,
Thank you.
I did the same thing! :ROFLMAO:;) Put the bike on the side stand as soon as possible!! Then get the foot peg/brake pedal mounting plate back in alignment. It's a tight fit so it might take some work, I used a little prybar wrapped in cloth so as to not scratch anything. Then use something long and round (screwdriver, etc..) to make sure the holes are perfectly aligned before putting the bolts back in.
You'll be very happy with the crash bar once complete. The Givi crash bar is very well made and the best looking one IMO
Here's a picture from the side in question (right). Just take your time getting everything lined up - It'll be fine 🍻 :)
Wheel Tire Fuel tank Automotive fuel system Vehicle
So glad I'm not the only one.. :LOL:
I'll try it today, thank you.
You have the side black plastic fit over the bar on the right, didn't think it was possible.
They really look good! :D
Yes, I just slid the plastic cover out of the way (did not remove) to access the bolts and then slid it back over once the bars were installed.
Hello,
Thank you.
Sorry for the off topic question, but are those Ducati factory foot pegs? My V4S came with the small pegs, and I can't find the bigger ones in the parts/ accessories section. Do you have maybe a part#? Thanks.
Discussion Starter · #13 ·
The first picture isnt my bike. I just found it and "Paint" it to show where I screw up.
2022 Ducati Multistrada PP
As for other options, I installed the red Hepco & Becker crash guards on my '22 MTS PP:
Tire Wheel Fuel tank Automotive fuel system Motorcycle
Tire Wheel Fuel tank Automotive fuel system Vehicle brake
Vehicle Light Automotive tire Automotive lighting Motor vehicle
Tire Wheel Fuel tank Automotive tire Vehicle
2021 Multistrada V4S
That picture is one of mine. I have the SW-Motech Evo footpegs which are adjustable and wider than the stock ones. Got them through Twisted Throttle. Just be aware that you have to get the mount for the Multi V4 and then the pegs separately.
Thank you for this information. I will check them out since Ducati has not offered a bigger footpeg option for the V4 and the older ones dont seem to fit. (y)
The bigger Multi 1260 Enduro footpegs are a direct fit. If you want the adjustability of the SW-Motech ones, here's a link to the mount, then the pegs themselves:
SW-Motech EVO Footrest Mounting Kit For Ducati Multistrada V4 '20- | Silver
Thank you! (y)
1 - 20 of 20 Posts
