MS1200 DVT \\ Fuel Tank Sensor Issues
1256 Views 3 Replies 4 Participants Last post by  TXSailor
2015 DVT. Under 5K miles. Never had a problem with her. I was taking a quick little backroad ride and noticed that my fuel gauge was intermittently jumping from 3/4 tank to zero fuel and back again. Rode back home, issue persists. I'm due for a service soon so I'll have them check it out then, but it's a three hour ride to the nearest dealer. I did put a tank of Ethanol free fuel in it the last fill up, which it hasn't had before. Could this be the source for the issue? Seems more electrical to me, but I'm no expert. Anyone else have this issue?
· Registered
Very common. Search the forums. Many people have had several sensors replaced on the same bike.
· Premium Member
Mine has never had a problem but my sensor was replaced under warranty 2 years ago... if yours was never replaced then that might explain the problem.
· Registered
The Fuel Level Sensors have gone thru 6 levels of "revision" since their introduction. I have no idea what revision my 2016 1200S (in service August 2015) had in it originally, but it was replaced under warranty in February 2017 and failed yet again in March/April of this year.
I gave up n trying to work thru the local dealers for warranty service so just ordered a replacement from Ducati Omaha ( $108) and fixed it myself. The latest part is a Rev F........
Ducati has used the same manufacturer for quite some time and evidently the small magnetic reed switches fail at some point....
Cheers, D
