1 - 3 of 3 Posts
I've got a Hypermotard and am looking for the throttle plate angle used for this model during the TPS reset procedure. I'm told it may be the same for the Multistrada 1100. Do any of you have a service manual and would be willing to share the idle angle? The angle for some Ducatis is 2.3 degrees. I'm wondering if the 1100 in the MS and HM use 2.3 degrees or 3.1, etc.
Thanks in advance,
17DoubleE
The TPS is reset by using diagnostic software through the ECU, it cannot be done by adjusting the TPS itself (I learned the hard way). You will either need to take it to a dealer to have them do it or use the Technoresearch diagnostic software:
http://www.technoresearch.com/Products/VDSTS-Motorbike/VDSTS-Motorbike
The reset procedure is very simple, and only takes seconds with this software. If you do your own service it's money well spent!
1 - 3 of 3 Posts
