This is what I do. I've mounted two long carriage bolts into a beam in the ceiling and hoist the front end with ratchet straps. You may be able to do something similar.
Two ratcheting straps over a 2x4 screwed into the wall with two more making an A-frame. Worked good. There is enough clearance in both sides also to put jack stands to support from the bottom.
The abba Front Lift Arm is a perfect addition to the Superbike Stand for lifting the front wheel or both wheels simultaneously off the ground with ease...
abbastands.co.uk
1 - 8 of 8 Posts
