We received our Streetfighter a few days ago. We finally found some time to work on it.
We have a lot of product for the Strreetfighter in stock.
so we replaced what we thought would make the biggest difference first.
Here are the results after our first day:
BST CF 7 spoke "Street" Front Wheel: 848, 1098, 1198, Streetfighter, HM
BST CF 7 spoke "Street" Rear Wheel: 1098, 1198, Streetfighter
We also added a pair of RHINOMOTO Front Axle Slider: Ducati 1098/848 and a CF Front Fender "Diversion"
The OBERON Clutch Slave Cylinder 29mm will reduce the lever effort by about 30%. It has become our favorite because it is easir to find neutral than the 30mm slave cylinders , the finish and color selection is good. The price is 35% less than the others as well.
A SPEEDYMOTO "Leggero" Sprocket Cover replaces the original plastic sprocket.
We reversed the linkage so we could get "racer" shifting. We will add a reverse shift lever later.
The MW Folding Clutch Lever: 999/1098/S4RS/HM-Black allow us to adjust to a more comfortable position. The folding feature reduces the likely hood of breaking the lever which can leave you stranded far from home or end your track day.
The OBERON "Bar End" Turn Signals: Black/Pr and CRG Blindsight Mirror are our favorites for turn signals and mirrors. They are hardly noticable when on the bike--yet the mirrors provide a very good view of traffic behind you. The turn signals on the barends light up front and back and can be seen day or night.
