Your brakes are obviously an essential part of your bike and, like any moving part, they require maintenance to keep them working as they should. Time spent working on your bike and cleaning up after the job’s done is time that can’t be spent riding, so anything that can save time in this area is a good thing. Motion Pro has a new tool called the Mini Bleeder that does both, and it is available from Riders Discount.
The Motion Pro Mini Bleeder combines a few different tools into one handy little package to take the hassle and mess out of bleeding your brakes. The wrench is floating and has 12 points to fit on the 8MM, 6 point hex of the tool body. This allows you to make small adjustments to be made in small spaces if necessary. A rubber seal inside the body prevents leaks and a one-way valve that keeps the fluid flowing in one direction. Fluid flows out the long hose that is attached to the back of the body, allowing you to route it into the catch can of your choice.
Motion Pro’s Mini Bleeder is a great addition to your tool box whether you’re bleeding your brakes once a year for the street, or every other weekend for the track. You can order yours from Riders Discount by calling Nathan at 866.931.6644 ext. 809, or by sending a PM through this forum. You can also feel free to shoot an email to FORUM at RIDERSDISCOUNT dot COM and we’ll get back to you right away!
This sells for $24.95
I wanted to write a review of this product which is actually very nice. There is a however though. It may not fit all 8mm bleeders and did not fit the ones on my Brembo Monoblocs. It will probably work just fine on rear calipers, clutch slaves and other applications but again, they also say in their literature that it may not fit all. Customer service confirmed this also.
I'm going to try something different but it is still a nice tool.
