1 - 3 of 3 Posts
Motion Pro Fork Oil Level Gauge
Pricing: $22.95
For checking and adjusting the oil level on all conventional and single chamber cartridge forks. Adjustable ring will measure oil levels from 0 to 300mm in 0.5cm increments
Syringe has a capacity of 60ml
Motion Pro Ringer Fork Seal Driver
$44.95
Available in popular fork sizes
Innovative design makes tool easier and safer to use than old fashioned pin aligned drivers
Anodized aluminum locking ring features knurled finish for secure no-slip grip and positively locks body halves together during use
No more worrying about part of the tool falling off and damaging the fork leg or hitting your feet
Perfectly weighted to drive seals
Body halves are machined from durable carbon steel and feature high quality protective black e-coat with laser engraved markings
Limited lifetime warranty
Motion Pro Fork Seal Bullets
Pricing: $4.99
Protects the fork seal and wiper of inverted forks from damage by the bushing groove during installation
Eliminates the need to wrap the fork tube with tape
Fitment size is marked on each bullet for easy identification
Multiple sizes available, sold each
Motion Pro Ball-End Allen Set: Metric
Pricing: $19.95
Made of chrome-vanadium tool steel
Sizes included 1.5, 2, 2.5, 3, 4, 5, 6, 8 & 10 mm
Ball end allows for better access to Allen-head bolts (up to 25-degree working angle)
Convenient holder included
Race Tech Adjustable Pin Spanner Wrench
Pricing: $59.95
RT Pin Spanners have a unique pin design with a reverse taper to keep them from popping out during assembly and dis-assembly.
Instead of investing in a different socket for every different for cap these pin spanners will work universally between fork cap diameter as long as the holes are still the same size.
Motion Pro Pin Spanner Wrench
$39.99
Unique curved billet aluminum arms provide clearance and ease of use
Stainless steel shoulder bolt pivot
Replaceable hardened tool steel pins
Includes 4 mm and 3 mm pins
Low profile pins provide added clearance on fork caps
Durable blue anodized finish with laser engraved markings
Designed for use on many forks and shock absorbers
Original Motion Pro design
* Register on the Motowheels website for Free forum passwords to access discounts on most non sale items or lifetime VIP passwords for access to the deepest discounts on ALL items. Look for memberships and choose the membership type that fits you the best
Discussion Starter #2
ATHENA Front Fork Seals
ATHENA Front Fork Seals [Showa Forks Only]: Ducati Showa Forks [Early SBK, Monster, ST]
$13.95
High quality replacement fork seals
Made in Italy
Seal Dimensions:
42mm ID
54mm OD
11mm Thick
ATHENA Front Fork Seals [Ohlins Forks Only]: Ducati MTS1200, Streetfighter S, 1098S/R-1198S/R, MTS1000S/1100S, 1199S/R, 1299 S
$23.95
Seal Dimensions:
43mm ID
55mm OD
11.14mm Thick
ATHENA Front Fork Seals: Ducati Sport Classic, GT1000, Monster, Hypermotard, SS, SF, & 848/1098/1198 [Base Models]
Price: $13.95
Seal Dimensions:
43mm ID
54mm OD
11mm Thick
* Register on the Motowheels website for Free forum to access discounts on most non sale items or lifetime VIP passwords for the deepest discounts on ALL products. Look for memberships and choose the membership type that fits you the best
ÖHLINS Fork Seal Kit and Oil: ÖHLINS R&T Forks: 43mm
ÖHLINS Fork Seal Kit: ÖHLINS R&T Forks: 43mm
Pricing: $65.95
Includes 2 dust and 2 oil seals for 43mm road & track forks
ÖHLINS Road and Track Fork Oil
$37.95 * FREE SHIPPiNG
High-performance fork oil specially developed for the Road and Track forks
Stable viscosity and negligible fade, even under hard use
Designed to minimize friction and wear on fork internals for longer service intervals
One liter plastic bottles
1 - 3 of 3 Posts
