Originally designed specifically for reaching those hard to reach screws on carburetors, the Motion Pro 90 Degree ¼” Hex Driver turned out to be a much more versatile tool than originally intended.
The Motion Pro 90 Degree Hex Driver has a shallow, ¾” depth that allows you to reach into the tightest of spaces. This shallow depth combines with the 17 ½” length to make sure that there are very few fasteners that will still be out of reach. At the end of the tool you will find a gear drive that you can turn from the handle. Turns can be made in precise 22.5 degree increments thanks to detent, but this can be easily removed if you prefer a smooth, free spinning feel without the clicks. The gear drive connects to any of the six included bits, one of which is a ¼” square drive adapter for limitless versatility. One thing to keep in mind is that this hex driver was originally designed for carburetors, so it won’t be the best choice for working on large or seized screws and bolts, but it’s 50 inch/pound torque limit makes it perfect for any of the smaller, hidden ones you might come across.
Make your next encounter with a hard to reach fastener much less frustrating by picking up a Motion Pro 90 Degree Hex Driver today! These aren’t listed on the RidersDiscount.com website yet, but you can get yours for just $57.00 shipped in the lower 48 states by calling Nathan at 866.931.6644 ext. 809, or by sending a PM through the forum. You can also feel free to shoot an email to FORUM at RIDERSDISCOUNT dot COM with “Motion Pro 90 Degree Hex Driver” in the subject and we’ll get back to you right away!
The Motion Pro 90 Degree Hex Driver - $57.00 shipped anywhere in the lower 48!
