As I would receive requests for more shim sizes, I have added a fair number of them to my shim inventory. Here is now the total inventory of shims by type. All in .05 mm increments except where noted.
8 mm Opener Shims- 1.00 to 6.30 mm (.05 mm increment except from 1.00 to 2.00 mm and 5.50 to 6.30 mm in .10 mm increments).
8 mm Closer Shims-5.00 mm to 8.50 mm
7 mm Opener Shims- 1.80 mm to 3.90 mm
7 mm Modified Opener Shims (used with MBP Retainers on 4V motors only)-2.00 mm- 4.00 mm
7 mm Closer Shims- 2.00 mm to 4.35 mm
6 mm Opener Shims- 1.70 mm to 3.55 mm
6 mm Closer Shims- 4.15 mm- 6.00 mm
Panigale Inlet Valve Closer Shims- 4.00 mm to 5.35 mm
Mike
