for you modaholics:
rear sets: for any of you debating whether or not to change out your rear sets, get it done. beyond the improvement in looks and weight (lots saved), you'll have the ability to adjust your feet and legs into a much more useful position. for those of you contemplating your next mod, i'd do this before anything else.
full termignoni exhaust: i'm not sold on the looks but they're an improvement over stock and the ECU seems to help with smoothing out the throttle response. i need to ride it up in the canyons to have a much greater appreciation but the roads up there are closed due to the recent fires. the sound is mean with the baffles removed and the added diameter pipes look the part. another weight saver.
DP tail tidy/DP comfort seat: self explanatory....and once again you would not believe how much plastic (weight) is removed along the way. the seat is a bit higher and helps with the forward lean/nut cracker issue.
crg bar ends: i personally couldn't stand the mouse ears so off they went. capped off the holes with 1/4" black plastic plugs from the local hardware store. i might entertain rizoma mirrors and reservoirs down the road.
carbon: DP pieces on the tank, sprocket and rear hugger...other pieces came with the S package.
etc: Pro Italia clutch cover w/ stainless springs...oem clutch plate.
on deck: pazzo's, reservoirs, marchesini forged aluminum wheels, and some light powdercoating of certain parts.
one of the easiest, better handling and confidence inspiring motorcycles i've ridden in some time. time tested motor and suspension. nothing fancy, and all about the ride, and perfect for the weekend canyon run. don't let the Monster line fool you; it will do everything you ask of it and then some. a real joy to ride.
enjoy (before and after)
