1 - 9 of 9 Posts
Yesterday was the first time I brought my S4R to the race track. It is the same track that I used to ride with my sportbike.
Compare to the handling of my suprtbike, with the same riding line, the S4R is a little bit under steering.
Folks have any suggestion about the setting of the bike??
Thanks,
oneducs said:
leave it up to the experts, i have a 01 S4 and i paid 50 bucks and let G.M.D. Computrack set my bike up. ask around the track for some help and info. good luck.
First "mod" would be to slide yourself forward onto the tank and getting as much weight forward as possible when exiting corners, if you aren't already. Lazy riding causes understeer. Next steps would be increasing rear ride height (is it adjustable independent of preload on the S4R?) and raising the forks in the clamps a smidge.
Super Moderator
Yupp..
Most Monster riders I´ve seen on the track have a few issues.
*Weight distribution - Many monster riders seem to convert from handlebars to clip-ons.
*Ground clearance while cornering - raised rideheight, modified exhaust and higher rearsets are the most frequent mods.
A friend of mine has heavily moddified his monster for track use. He is a VERY serios fellow when it come to modifications.
His homepage: http://www.ebbot.net/ducati/m900crsp/
ALL PHOTOS UNDER COPYRIGHT BY OWNER! NO FURTHER POSTING PLEASE!
His bike
My first ducati was my monster and I started doing track days with it. The limitatiions became evident immediately. I too had under steer and ground clearance problems. I had the forks resprung and revalved for my weight and bought an ohlins rear shock. I also raised the rear ride height. All these mods helped a bit, but the bike still seemed unsettled in the fast turns. I also was still scraping the pegs and pipes. I decided to not put any more money into the bike and just get a superbike. I bought a used 916 with Ohlin rear shock and just love the way the bike handles on the track. What a big difference in stability. The bike just rails around the turns. It feels well planted on uneven surfaces and really instills confidence going fast. I am sure some have sorted out the handling problems with the monster, but the superbikes were built for racing and there handling perfomance is exemplery. Just dial in the suspension for your weight and you are there.
Mike
I love my M1000 at track days. However, it is more fun on tight tracks as I've noticed a tendency to run wide on fast turns too. I don't do enough track days for that to really bother me yet, but if I start doing lots of track days, I might just have to get my hands on a dedicated track bike of some kind.
Discussion Starter · #7 ·
Thanks,
Thanks for advises from all, I will bring my bike to the next Ducati track days and wee what happen then.
Thanks,
1 - 9 of 9 Posts
