1 - 13 of 13 Posts
Helping my buddy part his M1200R out. Dropped a valve on the vertical head (2nd time!). Bike's in great shape cosmetically and all other components are in good working order. PayPal friends/family or 3% on top with goods/services. Shipping is free within lower 48 unless otherwise noted.
  • Ohlins black front forks - SOLD
  • Ohlins rear shock - $400
  • Ohlins steering damper - $250
  • Brembo M50 calipers - SOLD
  • Dash/key/ignition/ECU/BBS/lock set - $700
  • Termignoni exhaust - SOLD
  • Marchesini 7 spoke gold wheels from 1198S - $1200
  • Ducati Performance seat - $150
  • 1200R red seat cowl - SOLD
  • 1200R gas tank - SOLD
  • 1200R carbon fiber front fender - SOLD
  • 1200R front windscreen & fairing - $150
  • Headlights with NRC front blinkers, light scratch - $250
  • Ride-by-wire throttle assembly - $150
  • R&G Aero frame sliders - $150
  • Radiator with fans - $300
  • Upper triple tree - $175
  • Lower triple tree with 1 broken steering stop - $150
  • Complete right rearset with frame bracket with Ducabike footpeg and brake pedal - $150
  • Complete left rearset with frame bracket with Ducabike footpeg and shift lever - $150
  • Complete 1200R wiring harness - $100
  • 1200R Throttlebodies/airbox - $250
  • OEM Brembo 330mm front brake rotors - $175
  • Front axle - $75
  • Kickstand w/ bracket - $75
  • Clutch master cylinder - $100
  • OEM Handlebar - $75
And a bunch of other sensors and misc parts. If you need something that's not on the list, PM me.
Are you selling any of the engine parts? I'm looking for a cylinder head with cams, even the bad one would probably do.
M50 calipers do come with used brake pads. Lines on this bike ran to the ABS module. I do have some non-abs lines off of a SBK that i can include. Master cylinder of course isn’t included in the price.
Motor will be parted out as well. Vertical cylinder (where the valve dropped) is toast but horizontal is good
1 - 13 of 13 Posts
