1 - 2 of 2 Posts
I have a Monster 1100S I purchased which has a destroyed vertical cylinder head, barrel and piston.
I've been able to purchase a really low kilometer (8K) 1100 Evo engine plus the single plugs coils packs.
From the part numbers the EFI is identical on both, so my question is can I use my 1100S ECU with 1100 Evo engine, I'm running stock exhaust.
Thanks in advance.
Ian
the camshafts are different, so the fuelling will be different. the actual physical ecu will possibly be the same, there's two versions of the conti ecu. typically there's an early one and an "abs" one that's in all the later models and hm.
1 - 2 of 2 Posts
