For the M1100 owners, does your bike run like crap below 15mph? Like in 5-15mph or so traffic speeds, the bike lurches back and forth, throttle is way too sensitive (crack open the throttle and the bike bucks back and forth), and just a pain to ride at those speeds. It's so bad I almost dropped it twice maneuvering in a parking lot. So with 1st gear engaged, it's not really rideable unless you're going above 15mph - meaning at speeds below that you pretty much have to be slipping the clutch and can't engage 1st at lower than 15mph.
Even when slipping the clutch, it's really "crunchy" and grabby. This is my first bike with a dry clutch so I don't really know to expect.
The only mod I've done that could affect engine performance is a K&N oiled filter. I can't imagine that would cause such problems though. But if I recall, even before I put it in, it still ran like crap at low speeds. (I also put on a Rizoma clutch pressure plate, but I don't thik that would affect anything?)
Any others out there having similar problems?
