Pretty easy. You will see there's two thin pinch points on the connectors that will open up the tabs, and at the same time wiggle the connector off of the tank. Put some rags down underneath, as some fuel will spill out. I always mark one hose to where it goes just to make sure I put it back on the correct fitting, even though the hoses line up pretty much where they go.
