Hi All,
Having running problems with my 2012 Monster 1100. The bike does not run right, lack of power once the bike reaches operating temperature. When it is cold it runs perfect - tons of power. can pull the front wheel off the ground when cold with a blimp of the throttle. Once warmed up though there is no power - it is rideable but no where near the power. Starting off is difficult too - it sputters until the rpms are up - also ONLY when bike reaches operating temperature. When it is cold it is fine.
This began after I replaced the exhaust and remapped the ecu. I have cleaned the map sensor passages and replaced the hoses. I also replaced the front sprocket with a 14t because starting off sounded and felt like I was in too high of gear. The starting off is better with 14t but is just really masking the engine running problem.
Any ideas?
