I installed a fender eliminator kit. When I was just about finished with the install I checked the lights. Started the bike checked light and shut it back down. I then bolted the kit up and went to start the bike again and nothing. No lights no dash lights nothing. I found a blown 15 amp fuse and changed it but that didn't fix it. Are there any more fused anywhere else? Anything else to check?
Thanks for any help.
edit: I see there is an voltage regulator fuse by the ECU... Can someone tell how to get to this fuse?
