Hi
Thanks for the help on the pick-ups, but it seems like you sort a problem and the next one surface??? Hopefully sometime in the near future I will be able to ride the bike!!!
Want to know if somebody had the same problem and what they did or some advice. I have a 900S2, the fire(think it is) on the vertical cylinder comes and goes while you are riding the bike. When u are riding at normal or full tilt the power will suddenly be gone (running on 1 cylinder). What sometime work is to switch the motor off while you still running, turn the key further to the left and back on and suddenly you can continue on 2 cylinders???
I changed the spark plugs - NGK B8HS, change the resistor spark plug caps, while the bike idles it's got spark and there is petrol from the carburator.
Any ideas before I toss the bike off a cliff?
