1 - 2 of 2 Posts
Miscellaneous for 2010 Multistrada:
(Prices for pickup or add actual amount for shipping from zip code 92061)
2 rear axle nuts, $5 each, 2 safety wire rings for nuts, $3 each, 1 axle washer $1
Coolant Overflow Bottle Cap, $2
2 Radiator Caps, 1 used, $6, 1 new, unused, $25
Rear Eccentric Hub Assembly, high miles on ok bearings, Note snapring holds bearings pressed into alloy hub, $40
Exhaust, cat and tips assembly, removed from bike when new, $100
MotoMfg Steel Rear Axle Nut Socket, $24
Cooling system hoses and thermostat and breather hose, $50
New Unopened Parts:
2 OEM Shift Linkage Bolts (alloy), $1
ENI Antifreeze, $15
1 - 2 of 2 Posts
