No I didn't get anything with the mirrors, can I buy the relay separately,Did you intalled the proper relay with the new flasher.
The little black box that come with the new kit.
the dashboard setting for indicators to LED is only for the rear turn indicators, if you replace the stock incandescent bulb style indicators for LED indicators.There is a setting in the dashboard computer that allows you to change over to LED lights. You may want to try this first. Otherwise, you can get an inline resistor from Motrax which will slow the slow the flash rate. I had to do the latter with my rears as the computer setting did nothing.
There are some posts on this if you do a search you will find some good info.
Out!
The dashboard blackbox requires that the LED's consume 3.11 W, as the orginals do. Looks to me that you need to put a resistor on each side in parallel or serial. Could you please post the Watt's of your new LED's, then I calculate for you the resistor and how to place it. You should find the Watts either on the LED glass or in the owners manual.Fed up with the mirrors so replaced them with a pair with LED indicators but now they flash too fast, what can I do please ?????
I put some LED'S on the front of mine!Used a 80 ohm 5 watt resister in parallelFed up with the mirrors so replaced them with a pair with LED indicators but now they flash too fast, what can I do please ?????
Krill, it is all sitting within the dashboard blackbox. To sortout your issue, resistors is the easiest. If your LED's have less then 3.11W you need resistors in parallel, otherwise we need some extra power. Please post your Watts.Thanks for all the advice, after reading other threads I thought I might just change the relay but I cant find it on the bike, not even shown on my workshop manual disc, anyone know where it is??
ss?Krill, it is all sitting within the dashboard blackbox. To sortout your issue, resistors is the easiest. If your LED's have less then 3.11W you need resistors in parallel, otherwise we need some extra power. Please post your Watts.
Krill, difficult to say how these things are internally wired. I only can guess that the 4 lots are wired in parallel + an internal resistor.ss?
Each indicator has a strip of 16 very small LED's in lots of 4, the only thing on them is KOSO-72, does this mean anything to you, is there a way of measuring the watts
