Has anyone extended the stock mirrors for a better view (of things other than your arms)? Would a flat piece of plastic work to move them out, or does it need some curvature to match the fairing?
I'd buy a set if they look nice. Especially if they shipped with extended hardware.From pictures it appears an extension for it would be a rather simple 3D Sculping project for a 3D printer, black ABS. Since 3D printers by default honeycomb the insides of parts to any density you choose, weight would be negligible.
That's what I was thinking. Or pretty easy to cut out of a sheet of delrin/acetal. They shouldn't add much weight, though I would imagine anyone super-conscious of weight would move to a different mirror (or none at all) anyway.From pictures it appears an extension for it would be a rather simple 3D Sculping project for a 3D printer, black ABS. Since 3D printers by default honeycomb the insides of parts to any density you choose, weight would be negligible.
No, the picture shows a length extension for early superbikes. However, a similar approach could be used to machine an adapter for the longer Honda mirrorsStrega, Are you saying those adapters in your pic will enable someone to put Honda mirrors as pictured on an SS ?
