I have the TDMR's and I live in Finland.
The choke works very well, there is no starting issues even in sub-zero temperatures. The throttle response is really good. They also make a nice whistling sound with certain throttle openings.
The pilot circuit was very lean with the default settings, maybe because of German TUV regulations or then the jetting is for the small valve head on 96-97 models? The default needle and main jet (135) seem to be spot on.
I have stock air filter, airbox and exhaust and a wideband lambda installed.
I had an annoying lean stumble just off idle on 2000rpm slight acceleration (AFR went to 18), which didn't respond to larger pilot jet sizes, but I got rid of it with a smaller (0,5mm) pilot air jet and 27,5 pilot jet, which is a bit too rich (AFR 11,5 on slight acceleration, about 13 on idle and cruising) but works sweet.
I have more jets on order, the 0,5mm pilot air jet is obviously too small but I only had 0,5mm and 1mm drills and had to drill it from a #0 jet because no-one has them on stock in Finland.
My friend has bought a set of 41mm FCR's for his 900ss. I will post a comparison when I have tried them both.
