1 - 3 of 3 Posts
but can a couple of guys with 748-996 series with a full termi system post a pick of the mufflers (from behind). For the love i cannot get these cans straight at all. thaaaannnnkkk youuuu
rear 998
I don't know if this will help but it is a 998 with full 54mm exhaust. It was a PITA to get the thing to line up correctly. The PO had the exhaust on really crooked and like you it bugged me. What I did was remove all the springs, take off the front header and mid-pipe, then align the rear and bolt cans to subframe.
The midpipe and header I slipped together then pivoted it up to the engine and bolted down. It also helps to grease all the joints so that it easy to slide them in and out/pivot to aid in placement. Mind you this is on a 998 so IDK if these steps will work in your particular application. Good luck!
1 - 3 of 3 Posts
