Microtec M197 - Replacement ECU for DUCATI
$999.95 in stock
Unrestricted tuning ability, this is the only way to go! Unlike a DP ecu, Power Commander, or ECU reflash this ECU offers the ability of full custom tunes allowing the end user endless adjustability.
Injection and ignition control sytem, expressly developed to be employed on many DUCATI bike models, in replacement of the original ECU. All the original functions are kept.
Heart of the system is the MPC5534 Power PC from Freescale that with a core clock of 80Mhz, provide high calculation perfor-mances.
Full parameters costumization allows to employ this module in different working conditions.
Unit is provided with two identical pre-charged maps, suited for the bike model chosen.
This kit consists of:
- Stand alone ECU
- PC Interface
- PC Cable
- Tuning Software
This unit is fully compatible with the original DUCATI dashboard.
By means of an included adapter, the unit can be connected to an USB port of a common Windows PC. A 3D Windows application, is designed for customize and monitor all the system paramenters. The external BOX is constituted by a black plastic cover and an aluminum back. Four fixing points are provided to permit a simple installation on the original DUCATI support.
