The attached figure shows the definition of closer shim size. It is not the total height of the shim, but the distance from the edge of the counterbore in the top of the shim to the bottom of the shim. Some type of tool is needed to register on the edge of the counterbore. An 8 mm closer shim is shown, but the concept is identical with the 7 mm closer shim.
