So... 95 Supersport 900, veetwo cams, high comp pistions....
I just did the rings as it was burning a bit of oil in the back cylinder...
Broke in the rings carefully...
Next day took it on a spin to see how it was....
Bike seemed faster... guessing the rings are okay.
But soon massive smoking out the exhaust.. like mosquito fogging truck style amounts of smoke...
Limped it home and yeah, exhaust pipe is almost dripping w oil... But-- there's also a big oil leak on the outside of the horizontal cylinder...
I assumed it was one of the 0-rings between the barrel and head had shifted- and oil was leaking both into the combustion chamber and the exterior of the cylinder.
But looking at it now.. it seems the barrel/head interface is dry, and it looks like the exterior leak was coming from the tach cable interface.......???
And it was a pretty big/high pressure leak... big slick from the tach cable all the way down the engine.
I'm about to pull the head to see if I can figure what's going on....
But was wondering if a leaky tach cable seal- could somehow dump oil into the combustion chamber???
Or am I chasing several leaks at this point?
Any ideas?
Any ideas?
