OK I started out thinking it will be a simple rebuild of my forks to stop the oil gushing from them. All part of the rebuild process so no problem so far.
Searched the Haynes manual and the factory manual to confirm what my model came out with. Acording to everything I can find I should have non-adjustable Marzocchi USDs but mine has blue adjusters for compression and preload on them, top nut is 37mm, they have never been changed, somehow doubt they have ever even been rebuilt and I can't tell you much more then that.
Are these Marzocchi and how do I tell? I have searched the forums and am just getting more and more confused as it sems that there is no consistency to what chassis numbers came with what.
I want to make sure that I have the right seals and that the oil capacity is right as Haynes quote 390cc for my chassis number (015***) for non-adjustable and 440ml for the 98 model (mine was built second half of 97) again non-adjustable with the only adjustable one they quote (and dont define if it's Showa or Marzocchi) for monsters being 531cc.
any info would be a great help.
