1 - 3 of 3 Posts
do i have to have a flywheel puller to gain access to the mag? im looking for spark and think the mag has oxidation on it. thanks for any advice.
Nope. The coil and hight tension system on the mark 3 is external. Only the low voltage source is provided by the windings under the flywheel. Try an external 6v battery to check out your high tension. If it works then your flywheel needs pulling.
I guess to answer exactly what you asked:
YES, to get to THE MAG , you must pull the clutch cover and flywheel.
But I guess if you just need to access the COIL ( which I'm sure isnt affected by oxidation) Then its under the top frame tube under the gas tank.
But Im sure if you are wanting to check the Magneto, then you prob already know where your COIL is..............
Some people-
1 - 3 of 3 Posts
