I'm building a custom seat for a customer's 2006 SC1000 and thought I'd share the process. Warning: lots of cringe worthy photos below.
The basic guidelines were:
- All black leather solo seat with more aggressive styling.
- Keep the frame 100% stock. No de-tabbing or modifications.
The stock seat on these are absurdly wide so I wanted to slim it up a bit. I aimed to not go too far outside the frame rails, which would probably trim off a few inches of width. I also liked the idea of exposing those frame rails so this new seat would sit just above them.
I decided to try to use as much of the stock seat pan as I could for it's mounting, rubber bushings and rear latch mechanism.
Step 1 - I took off the rear cowl, pulled the upholstery staples and peeled off the seat vinyl and seat foam. Sorry, forgot to take photos of this but it's pretty straight forward. I used a small screw driver to pull the staples up enough to grab them with some needle nose pliers. The cover and foam are 100% reusable still. The seat pan however... well, on to
Step 2 - Trim everything off the seat pan that gets in the way of the new design.
I continued cutting, mocking it up on the bike, stepping back and cutting more...
The tool box storage was too tall, so it had to go.
