1 - 8 of 8 Posts
I bought a very cheap 1999 monster 600. I removed the silences to clean up the bike. I found that the outlet from the headers has and end plate looking like a restrictor. The diameter of the hole is 12mm. Is this normal? Is it a part of the reduction to 24kW (33hp). If so is it any more restrictions? Does the carbs have different jetting?
Sent from my SM-N960F using Tapatalk
there was a restrictor in swiss ones from memory. just a steel sleeve from looking at the parts list.
Discussion Starter · #6 ·
It is a swiss bike. Do you have any reference to this like a parts catalogue.
Wow now that's a restriction!
Yes I would get that out any way possible unless it has to stay for legal reasons. If thats the case I would swap it for a aftermarket system and save that one on a shelf.
1 - 8 of 8 Posts
