My power seems to cut out at the higher rpm's while in second and third gear.
Any ideas on symptoms?
I'm going to change the spark plugs, run some carb cleaner through it and drain the fuel as its a little old (3 months old), but i topped it off with a gallon of some 91 and it still did the same thing.
runs smooth and has great power at the lower rmp... I think it might be starving for fuel or spark...not sure yet.
Any immediate things to check for this newb?
93 900 ss, keihin 41mm dual carb kit, airbox completely open/cut up, 2-1exhaust, stm breather, fresh oil/belt change - 12k miles.
