1 - 6 of 6 Posts
What is the length of the standoffs (mm or inches) that go from the frame to the fairing on the full length 900SS fairings? I was going to machine some up but didn't have the dimensions to get that perfect factory offset. Thx
Is this what you are talking about?
If so, it's 136mm without the thread. The thread length is 12mm. The diameter is 14mm.
982233
Yes. I just realize I need the offset of the upper one as well if you have available. Thanks!
Is this what you are talking about? If so, it's 136mm without the thread. The thread length is 12mm. The diameter is 14mm.
Those are what you need for the full fairing, I think.
The upper front has a bit of offset bushing, and that's 16.12mm long. The hole is the clearance hole for the bolt.
982237
And then there's the middle post. 16mmOD, 79.50mm long, and it's bolted on to the frame from the back side. 12.50mm hole is drilled on the fairing side for a rubber well-nut.
982238
Perfect. Thank you. I'll make aluminum ones today while awaiting titanium tube and round stock to arrive to make final version.
1 - 6 of 6 Posts
