1 - 3 of 3 Posts
Basically my Low and Hi-Beam do not come on if I stop somewhere and restart on my 00' 996. I know my battery is in its last stage but this happens even after hooking it up to batt. tender overnight. I can use some advices on this matter if anyone had similar issues.
Thank you in advance:)
Replace your battery before killing your regulator: it is the culprit.
Check your regulator and its wiring (yellow wires).
Have you checked your connections? Left bar commutator health?
I will check it out. Thanx Again.
1 - 3 of 3 Posts
