You need to take it to someone that knows what they are doing, cause you have done enough damage already.
that's pretty cold shit, and as a fellow canadian, i want to apologize for that reply.
you can bleed the clutch yourself... not too difficult to do if you have the right tools and some patients. and FWIW, i hate using a bleed tool, unless it is the really expensive all metal ones that shops have ... the plastic ones that you can find in stores usually are not worth the money, as they tend to leak and bleed air into the system, imho.
so, for the above reason, i tend to go old school and use a clear plastic hose, a catch can, some shop rags and the appropriate wrenches to open/close the bleed nipples.
you will need the correct sized open ended wrenches to open the bleed valve nipples on the master and the slave. you will also need about 3 feet of the appropriate sized clear plastic hose (make sure it can handle clutch fluid), and a can to catch the bled fluid into. some shop towels are also a great idea, to catch any fluid before it hits painted parts. and finally, you will need some new brake fluid. depending on how old the fluid that's in the system is, you might not need to completely flush the system, but as fluid is cheap, you might as well completely flush it when you bleed the system. new fluid is always good.
the fluid brand you select is up to you .... i bet you will get as many opinions on brands of brake fluid as you will on brands of oil to use. just make certain it is the same type or a compatible type fluid. check your manual to make certain. on my 2008 hyper 1100 the owners manual suggests shell advance DOT 4. i use
ATE super blue DOT 4
i always start bleeding (and certainly flushing) with the slave cylinder, as it is the lowest point in the system.
1. remove the cap from the reservoir.
2. pull the rubber cap off the slave nipple, place the hose over the nipple and the other end of the clear hose into the catch can.
3. if you have a friend who can assist, this is the time to have them lend a hand. have them slowly pul the clutch lever in a few times, then on an agreed pull, you loosen the nipple enough, so when they are pulling the lever in, the fluid (and hopefully bubbles) start coming out through the hose. it is CRITICAL that they pull the lever slowly, and when they have the lever pulled in all the way to the bar, they keep the lever tight against the bar and you tighten the bleed valve, so that no fluid/air gets back into the slave. DO NOT over tighten the nut. snug is good. stripped is bad.
4. if you are going to fully flush the system, complete the same procedure as many times as required, until the fluid that is coming out of the bleed valve into the hose is clean and clear in color.
5. keep an eye on the reservoir fluid level, and top up as required when you are flushing/bleeding the system. DO NOT let the fluid get so low as to allow air to get sucked into the system.
6. once you have the system flushed completely, you can tighten the slave bleed valve completely (again, DO NOT over tighten), and replace the rubber cap.
now you move up to the master cylinder (if your 796 has a bleeder on the master... i don;t have access to a 796 right now, so don't know for sure).
1. remove the rubber cap off the bleed valve, and place the correct sized wrench on the bleed valve nut.
2. place the clear hose over the bleed nipple, and the other end into the catch can (you might need to use a table or step stool to rest the catch can on). this is where shop towels are good to have, to place over the tank shroud on the left side, and on top pf the front fender, under the master cylinder, just in case you spill some fluid when filling the reservoir.
3. it's the same procedure for bleeding the master cylinder as the slave ... pull the lever in SLOWLY a few times, then on an agreed upon pull, open the bleed valve to let the air bubbles and fluid come out. again, make sure to hold the lever tight against the bar on the pull that you open the bleed nipple, and close the bleed nipple when the lever is held tight, not allowing air/fluid back into the system.
4. it usually takes two or three bleeds of the master to get all the air bubbles out. take your time, and make sure there are not any bubbles coming out before you stop.
your clutch will really feel much better after doing a flush/bleed, so it is well worth the time and effort required for the task.
you will know when it is time to flush the system again, when the fluid in the reservoir turns from clear to a darker color.
for what little brake fluid costs, and the time required to do a flush, it's money and time well spent to keep the clutch hydraulics system clean and functioning well.
hope this helps.
if i have left anything out, i am sure someone will add the correction(s).
ciao,
johnc
