1 - 10 of 10 Posts
Ok, I was putting on my new to me LV slip on and cat eliminator and after about 2 hours of sweet, back pain and grime from head to toe the pipe is on the bike. I started to put things back together when I put the palm of my hand down where seat should be. I then lift up and hear the dreaded sound of metal on metal as a bolt falls towards the floor. I knew right away which bolt it was, the stupid LITTLE bolt that holds the rear wing/plastic piece on. :mad::mad::mad: Now I can't find it. Anyone know the correct size or who has one in stock? I swear that thing is stuck somewhere in or on the bike but I can't see it.
I'd guess 4mm w/ 1. pitch. could be 5 or 3
The local cycle shop said it is a 4x10 metric bolt. So I will have to see if Lowe's has metric in stock. Oh and what the heck does 4x10 mean? Either way I now have 2 on order from the shop, which will take a while to get in.
Senior Italophile
4 is the mm 10 is the threaded length
You're gonna love my nuts...
Lowe's, Home Depot or an Ace Hardware store should have it. Just look for M4X10(0.7), diameter, length, thread pitch.
The 4 is the diameter of the bolt and 10 which in this case is probably a mistake because this number is the distance between the threads. In this case if it is a 4mm screw, it would probably be a .70mm thread pitch. So if you imagine 10mm thread pitch it is impossible.
I thought the 10 represents how many threads are in each centimeter, just like the us standard.
Senior Italophile
You are right m4 bolts are a .7 thread pitch the 10 is threaded length I missed the last word, fixed it.
If you think about that you will see that it is impossible. 1 centimeter equals 10 mm right? The .70mm thread pitch means that if you measure between the peaks of the thread you will get .70mm.
1 - 10 of 10 Posts
