Not tracking it quite yet, as it's my first bike. Looks like changing just the front would be the most affordable option and let me keep my stock chain. What is recommended for teeth count/brand for the new sprocket(s)? Just wanna make it more ridable around town
RTnLSLtn
I've come across this article on the net not too long ago.
Hope it helps.
Regards
The best production superbike in the world. Period. Nothing comes close, not to the quality, not to the sound, not to the poser value, not to the fit or finish. Simply put the bike for those who demand the best. So why have you suffered through that ridiculous tall first gear? Change the sprockets and chain to the 520 - what they are supposed to be- and fix the gearing while you are at it with this special priced value package.
This fits all of the Ducati 749 and 999 and increases power response across the rev range. Dyno tests prove that you can reach peak torque and HP an average of .3 seconds faster than stock! Even with amazing copious amounts of torque, if you can't get the bike in the power range sooner you can't be going faster sooner.
Stock sprocket sizes for the 999 are 15 tooth front 36 tooth rear which has a final drive ratio of 2.40 Our optimum ratio is 14 tooth front 38 tooth rear which has a final drive ratio of 2.71. For the 749, optimum gearing is a 14 front and 41 rear.
Extensive testing on the street, eddy current dyno and on the race track have proven that this is the optimum ratio for your bike, however you may choose any combination of front and rear sprockets for your application.
