Hello, i just added a corse clutch to my 749r. IT did however came with stock springs/clutch caps Which are wrong for this clutch. 40mm and very weak
I ordered the black corse springs, Which just left me without the right clutch spring caps.
Am i right they are h=8 (height id 8mm) or do i need different caps for these.
Last but not least does anyone have a set of 4 for sale ?
Thanks in advance!
Clutch plate package is correct height
Springs need to measure 42.1mm.
These are 40 and develop way less pressure.
Yes i have ridden the bike and iT slips on Acceleration and to long on down shifts.
Had something similar occur on my MTS when I replaced the worn clutch plates at 35K miles with the Barnett P/N 306-25-10008 Clutch Plate Kit.
I had to buy new Ducati OEM P/N 797.1.053.1A springs because they are 45MM, and all the aftermarket replacement springs I could find were only 41MM.
Trust me, the 41MM springs don't work as I found out after losing 6th gear on the highway.
