1 - 8 of 8 Posts
My ST (04 MY ST4S ABS, Senna) has its 24,000 mile service coming up in a couple of months. Like other recent posters, I want mine to last forever and I want to start saving for parts.
Here is a list of what I've done so far: clutch in good working order, I replaced the clutch slave with an STM unit, new Pazzo break/clutch levers, new aftermarket mirrors, SIL oval pipes, 15/42 gearing, case saver from DesmoTimes, and PG's LED tail light.
In other words, I've done a lot of "bolt on" stuff. The engine's got more than enough power for me, so I want to leave her as she is... un-modded and running beautifully.
With that in mind, beyond the scheduled items for 24,000 mile service (and wheel barrings), is there anything that you all would recommend that I have replaced or upgraded to give my bike a proper reconditioning?
Thanks a lot for your input; look forward to reading your reponses.
Best,
1527
P.S. If there is a thread somewhere which covers this topic, I apologize in advance (didn't find one)...:D
Thanks, Bill, I am in the 220 (probably 235-240 when fully leathered up) region so a new spring might be in order. When you upgraded your rear spring do you recall what brand you used?
I will do a search too.
I replaced the springs and added gold valves for my weight 230#s, best mod I made. the spring rear was olins, front was race tech. Also replacethe tapered head brearings while you have the forks off.
Still needs a life.
I am in the same range. The new rear spring was an Ohlins.
1 - 8 of 8 Posts
