Hey guys I have a manifold that I'm trying to find longer studs for. It's an S2R 800 and the stock M8 studs don't even come close to what I need.
I'm looking at at least 2 1/2" - 3" idk what brand the manifolds are but they're way nicer than the stock.
I'm particular about it being pipe per exhaust port instead of joined like the M800 or M620.
I can include a picture of the exhaust manifold if that helps. I'd appreciate a direct link to a product since all my Google fu isn't turning much up. I'm gonna hit up my dealer later.
Maybe I don’t understand what your asking? You just need a longer M8 stud? You can easily buy from fastener shops, like fastenal, lightning bolts, Tacoma screw etc. or you could simply order from the internet M8 all-thread and cut to the exact length you want?
Still not exactly sure your goal but here we go. I have a S2R1000 on the bench and the 620 I have on hand are the same so I assume the 800 is also the same exhaust manifold stud.
Stock size is 8mm with 1.25 thread pitch and the length is 45mm.
So you need a 8mm stud with 1.25 thread pitch to whatever length you desire, as long as it is at least 45mm long. On a exhaust manifold I would recommend grade 8.
8mm has 2 different thread pitches. You can see in the chart, I highly recommend you spend a few dollars and also buy a pitch gauge which you see in the picture and the blue plate to help you identify metric or STD fasteners…it will make your future jobs much easier without guessing.
1014359
1014360
