Greetings and thanks in advance for your help...
So, i bought my second ducati, hyper 1100s. Took a gamble and had it shipped across the country on the sellers word and video that the bike was running. Long story short, it got here, and it don't work.
Original issue bike would crank, but no spark. Ran the engine codes, it was throwing 8 codes. Trolled the forums here found something on the crank position sensor, i decided to start there and checked the gap =.9mm (out of spec according to the service manual)
I cleared the codes after and boom she fired right up. Im assuming that gapping it cleared the gunk off and it worked again. So i got all excited and wanted to take it around the block so i hop on pull clutch drop it in to first and she dies, like i had the sidestand out. i checked the sensor and according to the diagnostic tool the sidestand sensor is functioning.
I go out again this morning after trolling some more the past couple of days for answers, and it did let me put it in gear and i manipulated the clutch a little which seemed smooth and appeared to engage and fully disengage. so out i go to go around the block and all of the sudden the engine starts revving like the throttle is stuck, i give a quick twist to see if that calms it down, which it didnt so i kill it.
Roll it back in to check the TPS on the diagnostic tool and it os reading 3.1 at idle (i dont think that is right from some of the threads i have read on here)
Im attaching some screenshots from my phone from the diagnostics tool with the engine codes and the infor from the bike while it is running.
Like i said in the title of my post, im looking to get some ideas on where to start and any advice that you may be able to share.
Thanks again
Thanks again
