1 - 3 of 3 Posts
Hey guys !
does someone maybe had a similar problem, so when I drive my Ducati 848 2008 over 2000 RPM my front light stop working andwhen I decelerate under 2000rpm le light comes back and show on my dashboard the orange triangle.
An someone suggest me something to do !
Thanks
- loose connection somewhere? Check frame ground connections and the main battery terminals first.
- Check regulator/rectifier output voltage at idle and when revving over 2k. Measure at the battery. It should be pretty stable around 14.4V over 2000, definitely not more than 15 or less than 13V.
1 - 3 of 3 Posts
