It's Warrington, PA spelled backwards....sorry! I own a 999 and replaced the 999 taillight assembly with a MS one. The MS registration light works better than my old unit with the Evoluzione kit light installed in it. I'm also running a Ducati Design LED tail/brake light.I have no idea, where are you located? I don't recognize you location on your profile.
Thanks Tim!What bike do you ride?
If you have a MTS1200, it has a "Number plate light: bulb type C5W (12-5W)".
Any Auto shop should have them. Osran, Narva brands etc. There are also LED versions that should also work if the CANBUS lets it.
Have you considered the LED tail light option from Blaster X? It's not very expensive and you can easily add actual stalks if you feel the need. I wired in a cheap LED strip for my plate light.Every time I try to drop the bulb in the 2nd hole, it pops out of the first or slips out of the needle nose and falls on the ground. I tried for a good 20 minutes.
Major value add post.....thanks for this, Scott.I took a wire twist tie and wrapped it around the new bulb (LED) and used the wire to hold onto to set it into place. popped right in first time ,after a few (read many)failed previous attempts, with needle nose pliers and roach clipsand whatever else I tried.....
HA HA HA Ha .... the laughter is from the Ducati designers giggling at us!
My Sausage fingers and almost upside down positioning was making me mad.
I took a wire twist tie and wrapped it around the new bulb (LED) and used the wire to hold onto to set it into place. popped right in first time ,after a few (read many)failed previous attempts, with needle nose pliers and roach clipsand whatever else I tried!
My Lens cover broke at the tab, sos I Siliconed the POS in there Temporally (unless it works that is) that was last summer.
Easy.
