1 - 3 of 3 Posts
my asv c/5 shorties just came in.. in a few days i'm dropping my bike off to have my tank replaced. anyway.. is taking off/installing levers as easy as it looks? or since i'm bringing the bike in to get work done just have them swap 'um?:confused:
Discussion Starter #2
couldn't of been any simplier? less then 10 mins to change out the levers! starting to think maybe i should of went with a long lever for the clutch? o'well it is what it is?
Big fan of the shortys. I've had Pazzo and CRG. Same feel different looks. Loved them both. Running RCS shortys now.
Levers are a simple install.. If they do it for free go for it. If not.. Do it yourself. If you know how to use a door knob you can install the AVS..
Not sure how it came about but I use two fingers for the clutch and one for the front brake which is why I went RCS. I just can't get used to two finger braking so I needed more power with the RCS.
By and by. RCS master cylinders ROCK!! Def worth the cost when you are ready.
1 - 3 of 3 Posts
