1 - 2 of 2 Posts
Hello All. I have a sequential LED tail light turn signal for my 01 748. I have regular OEM turn signals upfront. Brake lights and left turn signal work fine but right turn signal will not go on. If I play with the high beam button I can get the right side to briefly turn on. Looks like everything is plugged in right. Disconnected and reconnected the terminals. Am I missing something? Thanks and merry Xmas.
You might need a LED compatible flasher unit or a resistor in the circuit for it to work properly. Make sure the light is grounded properly, to the spot on the frame where your battery grounds is best.
1 - 2 of 2 Posts
