1 - 2 of 2 Posts
Got the LED indicators working good with resistors and are flashing normally, but now when the ignition is turned off the right indicators flash 7 times before stopping ? what is causing this ?
Without the resistors the indicators flash very fast and also make the other side flash as well but not as bright .
Does any one know what is required to fix this on a 2006 Supersport please:confused:?
If you have a single indicator warning light on your dash, you'll need to do the diode mod to it. Search 'dim dash lights' and you should find some posts on what you need to do.
1 - 2 of 2 Posts
